240 not starting
Old Jan 28, 2011 | 04:38 PM
Undyin's Avatar
Default 240 not starting
Hello, My 1996 240DL will not fire at all any more
not the spark plugs and i think its fuel related. any help would be appreicated.
Old Jan 28, 2011 | 07:49 PM
swiftjustice44's Avatar
Well, assuming your diagnostic tools are at a minimum...do this. 1. With a helper trying to start the car, peek down the oil fill neck and see if the camshaft is turning. If not, your cam belt is broken. 2. After turning it over check the plugs to see whether they're wet or dry...that will tell you if you have fuel. If the plugs are dry, then there's a good chance the issue is fuel related. So...what year is your 240? They were discontinued after the 93 model.
Old Jan 29, 2011 | 04:59 PM
Undyin's Avatar
Lol i misstyped its a 1986 240.
But im pretty sure its fuel related because we took off the fuel filter and tried to start it (fathers idea) and no fuel was squirting out
Old Jan 29, 2011 | 07:23 PM
Well, your Dad was right! The next thing to do is remove the fuel feed hose from the back of the under car pump...that will tell you if your intank lift pump is working. Are you listening to see if the under car runs for a moment when you turn the key? To listen to the intank pump, you can use a length of hose and use it as a stethoscope. If neither pump runs, then odds are you either have a blown fuse or your fuel pump relay is bad.
Old Jan 30, 2011 | 03:01 AM
Titan Joe's Avatar
One thing to bear in mind, if the hall effect sensor does not work, the fuel pumps will not work either. At least in my LH2.2 car the pulsing signal of the hall effect also gives the go for the fuel injection computer. I would pull off the fuel pump relay cover and with the key in the run position, close the relay contacts and see if the fuel pumps run. You can also bench test the pumps with a 12v source. Basically my point is make sure they they don't work before you replace them. It still could be a simple fuel pump failure.
Old Jan 30, 2011 | 02:51 PM
Undyin's Avatar
My parents bought this car for 500 bucks so if its the internal pump itll probably go to a scrapyard. and i will keep that in mind even though your talking to a computer nerd not a car nerd lol. (i have no clue what that is! lol)
300td
Jul 25, 2011 12:26 AM
turtlepower
May 1, 2009 12:12 PM
pikey
May 10, 2007 01:34 PM
norkarsap
Jun 12, 2005 02:15 AM
