1989 240DL no spark after coil?
Could be your RPM sensor located behind the engine and on top of the flywheel. This is what triggers your spark at the coil through the ignition control module. Common for these to fail. Inspect it for chaffed wires near the firewall. Could also be the ignition control module - not as common. Good luck!
Kim Gregory
02-20-2013 08:02 AM
