rough starts on cold mornings - '92 240
Old 11-21-2010, 09:59 AM
coolson's Avatar
Default rough starts on cold mornings - '92 240
I've done a few repairs recently trying to hunt this problem. Put in a new fuel pressure regulator, literally took me 10 minutes. Put in a new crank sensor, was slightly more of a challenge, but still didn't need to leave my driveway. Still having trouble, I changed all 4 sparks, and had a bad section of my exhaust repaired. To my surprise, the exhaust fix seems to have had the most positive effect on performance.
A few months back a mechanic friend was positive the issues I was having could be blamed on a bad in-tank fuel pump. He put that in, but it didn't seem to have any effect. My problems then were stall related, and sometimes trouble starting.
With the arrival of the cold weather in New England, I have been dreading getting up for work in the morning because she is having trouble getting started. When the temperature gets down there, it'll turn over and start no problem, but it'll be the roughest most awful idle you've ever heard, and she'll cut out after about 10 seconds of agony. She'll get started smooth eventually, but it takes a whole lot of key turning and gas pedal finagling. Fortunately, with a exception of a few mornings, it hasn't been too cold. But surely that won't last.
Lastly, once I get over the initial rough start, it'll run like a top all day. Starts up no problemo and drives without any hiccups. Then the morning comes..
I guess ultimately I am just really hoping this isn't a fuel pump issue. Help!
Old 11-21-2010, 01:06 PM
davesee1's Avatar
i've just started a thread for this exact problem.
possible fixes include what you have already done, plus
1) checking the cold start valve/injector
located underneath the manifold. very difficult to get at, but if you remove it from the manifold and try to start the car, fuel should squirt out for 12 seconds or less.
2) temperature sensor
i believe it tells the ecu to turn on the cold start valve
please post a resolution when you find one! all my searches have ended in possibilites and no resolutions!
good luck.
Old 11-23-2010, 11:10 AM
coolson's Avatar
so;
IAC valve, cold start valve?
my gut tells me that the problem comes from too much O2 versus too much fuel; so at that, the IAC valve...? Seems to be about $200, which is 1/4 of what I paid for this vehicle.
I should say that this car is VERY clean; it would be hard to imagine the problem stemming from an overly greezy part.
SO, IAC valve. Where is it located?
Also, right behind the left headlight I found a dangling connection, a loose connection not plugged into anything. I figure it exists for a higher-end option not available in my vehicle. The tip of the plug is blue (a reference to cold, perhaps?) It is bundled with another wire, this one is connected right underneath the coolant tank. I unplugged it and switched them, the blue loose plug is the same connection. Is this meant to go somewhere? What happens if I plug it into the socket under the coolant tank? Sorry if i'm being vague, I'll try to get some photos.
Any comments or suggestions would be appreciated, as always.
Old 11-23-2010, 12:10 PM
740_300K's Avatar
I have this problem as well...though not quite as bad. When I replaced the plugs, cap, & rotor, it helped tremendously. Now that snow is trying to fly, and it is cold, it is coming back again. Check your air filter, too. My problem was worse when it was well used...like 33,000 miles old. I chalk mine up to being an old car with a lot of miles on it...305,000 miles. Low compression from worn rings/cylinder walls will do this as well.
Old 11-23-2010, 12:37 PM
coolson's Avatar
I've got about 140k. Plugs are new, fuel, oil and air filters are new. And like I said, this is a very, very clean brick, inside and out.
Old 11-23-2010, 11:30 PM
740_300K's Avatar
Mine finally quit starting tonight. Where is the crank sensor on these engines?
Old 11-24-2010, 07:21 AM
coolson's Avatar
The connection goes right up to dead center on the firewall, I'll post pictures later if I have time. Very easy to locate; black wire a little over a foot long. There is just 1 nut that secures it where the block meets the bell housing. everyone i talked to was skeptical about this being a cause, but when i pulled it out it was almost in pieces. surely this repair helped, but with the arrival of cold weather, turned out to be the tip of the iceberg.
Old 12-10-2010, 09:09 AM
coolson's Avatar
so, exceptionally cold yesterday and today, will not turn over. tries and tries and tries, but just won't do it. any tips or tricks? something else i could be doing? is this a bad a fuel pump?
i talked to a mechanically inclined friend and he suspects the timing belt. is this plausible?
please help, i'm desperate.
Old 12-10-2010, 12:04 PM
bubba240's Avatar
My guess is you have a vacuum leak somewhere. Look for any split or disconnected lines. What section of the exhaust was repaired? Any exhaust leaks before the o2 sensor will mess things up. The o2 sensor should also be checked with a volt meter to make sure its working.
Make sure there are no holes in the tube that goes from the air mass meter to the throttle body.
Old 12-10-2010, 12:35 PM
coolson's Avatar
no vacuum leaks. actually just got her started, and to my dismay was presented with a check engine light. pulled codes, COOLANT TEMP SENSOR. had suspected this a few weeks back.
seems like an inexpensive part. anybody know anything about ease of installation?
Akiles
2001-2013 model year XC70
03-13-2015 10:29 AM
dman777
12-19-2011 11:31 AM
KatieK
11-11-2010 10:29 PM
calvinhoe
11-11-2010 12:16 PM
Mecheng
02-24-2006 12:25 AM
Quick Reply: rough starts on cold mornings - '92 240
