1990 Volvo 240 brake light problem
Old 07-30-2012, 05:46 PM
zhandfull's Avatar
Default 1990 Volvo 240 brake light problem
I have a pretty clean low mileage 1990 Volvo 240DL. When I bought it a week ago all three brake lights didn't work. At some point they started working for about a day and now they are out again.
Trouble shooting I have 12V power at both sides of the fuse. I bought a stop light switch to install but it looks nothing like the one on the car. The switch on the car has a vacuum hose connected and a small two wire fitting. I disconnected the wires from the factory switch and installed a jumper still no brake lights. I read there was a relay on some of these cars just not sure what one is for the brakes.
Anyways anybody have a link for a wiring diagram or thoughts on the problem?
I checked the light circuit boards and they look to be in good shape. I wouldn't expect all three to be out anyways.
Old 07-30-2012, 08:01 PM
lev's Avatar
lev
lev is offline
It's probably the Bulb Failure Relay. At least that's what it'd be in a 740/940. I am not sure if the 240 have that but I think they do... It's a big round red job and causes what you describe--no brake lights at all...
The switch you describe is the Cruise Control Vacuum Dump Switch. The brake switch is further up.
Old 07-30-2012, 09:17 PM
zhandfull's Avatar
Thanks for that information I will look a little farther up and check for another switch.
Edit:
Found the switch up above the steering column pulled off the wires and tested new switch no luck. I did see the red cylinder type electrical connection that will be next, looks easier to replace than the switch just more money.
mattem
05-14-2020 08:39 AM
s10lowrider1994
11-16-2014 09:27 PM
craigshensel
06-13-2012 03:11 PM
keg22
03-13-2010 06:03 AM
dldunckel
01-20-2010 07:02 PM
Quick Reply: 1990 Volvo 240 brake light problem
