1991 volvo 740 break job
Old 01-21-2009, 04:26 PM
dholmes83's Avatar
Default 1991 volvo 740 break job
wondering what will happen if i just do pads and do nothing to my rotters ??
Old 01-21-2009, 05:54 PM
78vovlo244's Avatar
Default RE: 1991 volvo 740 break job
You will be fine with just doing pads for now i actually just did that myself but it is a good idea too do the rotors as well or you could just do them later and everything will work just fine.
Old 01-21-2009, 06:04 PM
victory's Avatar
dholmes83, you got squeaking breaks? Just wondering, cause that's what I have and I just want to try new pads first.
Old 01-21-2009, 06:35 PM
dholmes83's Avatar
no my breaks don't sqweek they i had ne tires put on and they said i needed a break job but idon't have the money to replace every thing right now but befor the pad really dig in to my roters i fig i would do pads first if that is a ok thing to do and do the rotters when i get the cash flow
Old 01-22-2009, 12:28 AM
tedv's Avatar
There is NO NEED to touch the rotors if they are not warped or too thin. If you car doesn't shake while braking, then don't worry about the rotors. Shops like to do them for the extra $.
Old 01-23-2009, 05:29 PM
dholmes83's Avatar
what type break pads should i get ceramic, organic or semi metallic not sure the pros vs cons of the differnt types ... all your help would be great ..
Old 01-24-2009, 12:02 AM
tedv's Avatar
I use PBR for my Volvos-good prices, no squeal. Ceramics are pricey, more metal, more squeal. Organic are cheap and soft and don't last too much...
Old 01-24-2009, 08:27 AM
dholmes83's Avatar
sorry for so many questions just want to do it right how do i find out if my car has abs ??
Old 01-24-2009, 09:48 AM
tedv's Avatar
I believe ALL '91 Volvos in the US do have ABS. Under the hood, on the passenger side there should be a good size metal box with brake lines coming out of it and it should say ABS, Bosch, etc. on it.
Old 01-26-2009, 03:48 PM
victory's Avatar
I have a '90 740 gle wagon. Do I check under the hood in the same spot to see if I have ABS?
Old 01-26-2009, 04:38 PM
tedv's Avatar
Yes. Also on the dash there should be an ABS light along with the rest of the warning lights when the key is ON-don't even have to open the hood for that one.
steelheaddan
02-05-2011 06:54 PM
jollygoodgold
01-31-2011 09:24 AM
colgate41
01-11-2008 12:15 PM
Scott6
11-16-2007 08:53 PM
colgate41
08-10-2006 12:29 AM
Quick Reply: 1991 volvo 740 break job
