1992 940 Sunroof removal
RE: 1992 940 Sunroof removal
you will need to take the headliner out...this link helps with the headliner removal but doesnt specify how to take the sunroof out...
http://ipdusa.com/pdf/PI-240headliner700.pdf
once you get the headliner out it is pretty easy to see all the bolts that hold the sunroof up. also remove the drain tubes at each corner. when i took my headliner and sunroof out i had to take the front seat out so the headliner would come out with out breaking it, they are somewhat fragile. if you have a waggon you shouldent have this problem. the sunroof is a little tricky to take apart and put back togather but after fiddiling with it for a while i got it back in place.
