1995 940 wont start
Old 07-22-2012, 10:30 PM
trout-19's Avatar
Default 1995 940 wont start
1995 940 turns over lots of voltage wont start . Fuel pump ? thanks
Old 07-23-2012, 02:55 AM
sicnarf's Avatar
What he says I think is that he has a 1995 Volvo 940 that does not start although he has lots of voltage in his battery.He is wondering if its the fuel pump that could be faulty. Trout-19,when you try to start the car does the needle on your tachometer gauge flicker? And if it does not flicker then your fault is the crankshaft sensor wire thats done.Its pretty cheap to buy and easy to change but you got to get under the car to change it and its hidden there.Google the sensor wire and you can see the pictures to know what I am saying and it will be easy for you to check if thats damaged/cracked/split under/between the car motor and gearbox
Old 07-26-2012, 12:18 AM
trout-19's Avatar
crankshaft sensor and new cap and rotor runs great thanks sicnarf
Fern Schmidt
2001-2013 model year V70
08-13-2013 06:43 PM
Tony oakley
01-20-2012 01:51 AM
chadman551
09-16-2009 09:38 AM
chadman551
09-14-2009 07:35 PM
furball3
01-28-2007 03:31 AM
Quick Reply: 1995 940 wont start
