1994 945T / 1987 745T parts compatibility
I have a 1994 945T and found a parts car for sale near me for $500 it is a 1987 745T with 150k miles, has a starting issue, but ALL exterior body panels are in EXCELLENT shape, has a sunroof, good glass, all windows work, decent interior, solid motor/trans other than the starting issue (has some rotted floor boards/subframe anchor points which is why the starting issue isn't being fixed by the owner) Just wondering how many parts (Body/Mechanical) are interchangeable with my 94 945? Need to act fast so any help would be great. Thanks
You want a parts car? This is not a good candidate... There are some parts you could use but many are different. The body is the same from the front back, interior is different, dash is different, engine is similar basically but not quite the same, the electronics are different... ABS/SRS are different. Brakes are different... Trans is different... I'd stay away. You could use may be a 1991 745, but '87 is too old.
sdguy
01-21-2011 02:59 PM
sdguy
08-11-2010 08:18 PM
