86 240 dl split rubber boot
Not sure what the part is called....the rubber boot between steering gear and tie rod is split. How important is it to fix this immediately? Is this something that can be done while having an alignment done? How much should I expect to pay to have this done? Is it hard to do myself? (bearing in mind I have zero mechanical aptitude)
Thanks
John
Thanks
John
RE: 86 240 dl split rubber boot
I call it a rubber boot but the technical name is bellows.
The bellows is supposed to be filled with oil and should be replaced as soon as possible. I do not know what it would cost as I live in the UK but it is a straightforward job. It means releasing the ball joint and unscrewing it from the steering rod. Remove the old bellows and replace with the new. It is clamped at both ends. The large end is clamped first then 0.4 US pints of engine oil (20w-50 or 20w-40) is pushed in the smaller end with an oil gun and the clamp replaced.
Everything is put back together and the alignment must be checked.
Having researched how to replace the boot, I'm not sure I have the tools (or mechanical aptitude) to do so. A guy at work tells me there is a steering rack boot that can be installed without undoing the tie rod. You basically cut off the old one and put the new one around the joint rather than threading the tie rod through it. Has anyone heard of such a thing? If so, where can I find it?
Thanks
Thanks
Where can I get one of these universal boots for steering rack? (I have found them for CV joint but not steering rack). I don't have the tools to do the job "properly" and it looks fairly difficult , especially considering the effect it might have on alignment. I figure a universal boot has to be better than doing nothing. Any thoughts?
