92 240 electrical
92 240 electrical
Hi, I am hoping perhaps someone can help me with a strange problem. My 92 low mileage 240 has had a dead battery if not driven for a day or two over a perieod of two weeks. It turns over right away when jumped, but power drains shortly thereafter. Someone suggested the power door locks in this model have been known to drain the battery. I disconnected the fuse that powers the door locks, and haven't had any more problems with a dead battery. Problem solved.(partially) But, the speakers, overhead light, trunk light and a few other incidentals, (but annoying when not working) are also connected to this fuse. Can anyone possibly lead me through disconnecting the power door locks so I can return the fuse so the other things will work? Is there a door lock motor in each door or is there just one? Any help or suggestions would be appreciated. Thanks
RE: 92 240 electrical
When I saw your question I was wondering where the relay was located. I've never really looked for it before, but I looked it up in a repair manual. The relay is located behind the center console near the top (somewhere around the vents). It should look something like the pic below with . Just pull the relay and the battery drainage should stop.
likesspace
06-18-2007 11:11 AM
