'92 240 w/rear light issue...
Old 04-18-2007, 10:17 PM
AAER's Avatar
Default '92 240 w/rear light issue...
ok,bulb malfuntion ind. came on replaced both tail lights as to match bulb voltage and noticed that one of the bulb on the right rear had started to melt the "papery" circuit.Now it is blowing the fuse for right side parking lights. As I saw in a previous question, w similar problem i did buy these from lampsandlenses.com ...wondering if replacing the circuit paper would fix it? and if so, can i use one from a wreck if it looks good?
Old 04-19-2007, 01:23 AM
Default RE: '92 240 w/rear light issue...
Ya you can use one from a reck.Just don't mix the sides up.Make sure the white bulb socket for the brake light is on the right side. Also if the paper circuits look very cheap. I would replace both with factory. Seen to many problems with cheap paper circuits. One other thing to look for is wear at the conections were the black plugs go and for you bulb sockets thats if you go used. good luck.
Old 04-19-2007, 06:32 AM
AAER's Avatar
thanks..ill try that
commoncold
07-22-2014 05:41 PM
gstrussman
09-07-2012 11:53 AM
vipul_vips
09-16-2010 01:30 PM
kurdtpatton
08-19-2010 09:38 PM
Bruno937
03-08-2009 12:41 PM
Quick Reply: '92 240 w/rear light issue...
