940 GL Transmission Problems?
Old 03-15-2007, 06:02 PM
flgal's Avatar
Default 940 GL Transmission Problems?
Hey guys! I am having a couple of issues with my 92 940 GL. First of all, I am not all that mechanically inclined...but can hold my own when needed. Here are my issues:
1) When it sits for more than 4 hours or so, it takes about 2-3 miles of driving to get it to change out of 1st gear (it's an automatic). I checked the transmission fluid and it is full and pink in color.
2) The odometer does not work, but the speedometer does. Would this be a gear inside that is broken and if so, is it hard to change them out?
Any help would be appreciated. I'm trying to not spend a ton of money on it, so I need all the help I can get at this point. Thanks in advance!
FL Gal
Old 03-15-2007, 10:14 PM
wojeepster's Avatar
Default RE: 940 GL Transmission Problems?
It usually is a gear inside and they are available
http://www.odometergears.com/subpages/volvo.html
Old 03-16-2007, 11:46 AM
flgal's Avatar
Thanks for the link! Would you know where I can find info on replacing it? Is it difficult? Thanks!
FLGal
Old 01-09-2008, 11:05 PM
Hello All ,
I am new to this forum as well and I have the same question as my compaion here on the transmission. I have a 1993 Volvo 940 (automatic) and I have the same problem with the transmission not shifting out of first gear for 2 or 3 miles. My fluids are just fine . I even added Lucas transmission additive . What do you all think could be the issue ? Filter ? Gear ? Whole tranny?
Tony
Old 01-10-2008, 12:44 AM
TedH's Avatar
sounds like a servo in the trans is sticking, may need a rebuild.
Old 03-04-2012, 02:56 PM
pehoffer's Avatar
In my case the kickdown cable was stuck so it was shifting as if I had it floored all the time.
Old 08-28-2012, 05:20 PM
b.rad.please's Avatar
where is the kickdown cable and how do I diagnose the problem.
are their any manuals available?
for me, 1st gear is fine, but shifting to 2nd onward is pure luck.
in advance, thank you for your time.
Old 08-28-2012, 08:05 PM
please start a new thread with a new car and problem, and identify what year/model car you have...
the kickdown cable comes off the throttle pulley, and heads back and down to the transmission. when the throttle is completely closed (no gas pedal at all), there should be a slight amount of slack in the exposed end of the cable, and the little bead on it should be just a hair outside the end of the ferrule adjuster, which normally has an orange plastic dust cap on it. when you step on the gas pedal, you should feel a 'cam' or 'notch' action before the pedal is fully floored (test this with the engine off), thats the kickdown.
jeffrisley
06-14-2015 01:48 PM
Jakeness
10-18-2011 09:36 PM
cosmo
11-24-2009 04:37 AM
ogotaj
03-22-2008 02:57 AM
volvo13
10-09-2003 01:36 AM
Quick Reply: 940 GL Transmission Problems?
