940 radio removal procedure
Old 06-18-2005, 09:38 AM
pisque's Avatar
Default 940 radio removal procedure
Can someone please tell me how to remove the original radio from my 1993 940 wagon ? Thanks for any help.
Old 06-18-2005, 10:18 AM
Default RE: 940 radio removal procedure
Hi,
First pull the ***** straight off. Don't be afraid to pull hard...
Then the selector rings behind the ***** pull off.
There are square retaining clips outboard of the shafts. You can see them by peering in at the shafts. These must be pried toward the shaft while pulling the radio out. I can never do both actions at once so I get help from the Significant Other. [&:]
ALSO if the radio resists coming out, there are anti-rattle clips at the top of the radio that can hang at the plastic surround. Might need yet another hand to pry these down while pulling. Don't use too much force, you could break the surrounds.
Old 08-02-2005, 04:59 AM
Hi
I have 940 Turbo Wagon, model 1998. Mine Radio is working fine, but when i insert the Audi Cassettee in it, the display says, Audio but there is no sound. The reverse and forward buttons fo the Audio cassettee are also not working
Anyone who could guide as what could be the problem
Regards
Old 08-02-2005, 09:26 AM
ORIGINAL: Qamar
Regards
Hi Qamar,
Repairing the cassette doesn't sound like a cost-effective repair...OE radios seldom are. Around here you are talking $100 USD just to have a repair place look at it, and that's after it's removed from the car!
I know you are on the other side of the world, but why not just upgrade to a newer radio? I just installed a $170 Pioneer radio/CD in my '94 'cause the OE's volume control was failing.
I bought mine at Crutchfield and the installation was rather easy...required the soldering of 15 color coded wires onto the supplied adapter harness. If you have any questions ask NOW before I forget!!! [&:]
Old 08-03-2005, 03:14 AM
Thanks for the tip. Will definately ask you if the need arises....
icebrick
10-22-2013 08:39 PM
jackfk
05-20-2010 08:56 AM
garyraygray
Engine & Internal
10-28-2008 03:42 PM
Cornfed
04-15-2006 09:16 AM
Majki
04-29-2005 09:52 PM
Quick Reply: 940 radio removal procedure
