940 Tutrbo to Non Turbo?
Has anyone done a TURBO to NON TURBO conversion? I am aware of the opposite conversion on lots of models but was wondering if anyone has done it and the degree of difficulty. Would the computer have to be changed or reprogrammed? Anything else I should think about???? I have in mind primarily doing it with 940 or later 740.
RE: 940 Tutrbo to Non Turbo?
turbo engines are designed with a different compression ratio.. it would probably feel very sluggish when driving. ALOT more then an original non turbo model. you can change the computer and do whatever you want but the engine still remains the same. unless im mistaked and they are the EXACT same engines.... but even though the engine model numbers are the same. some of the internals can still be different.
chithodt
06-11-2015 11:20 PM
