940 volvo battery
940 volvo battery
I went to take my battery out to go get it charged at advanced auto and to my fu....n surprise I couldnt take it out. On one side they have a metal post thats weld up against the battery and on the battery tray they have a groove where the lip of battery is tucked under it. I suppose its so people dont steal your battery but did they ever consider you yourself might want to remove it.
I was so aggravated......Joe
p.s. Finally got a jump when my neighbour got home 5 hours later. After i got it jumped the abs light came on and stayed on...Did i fry my air bag system and if so do you need that to pass inspection?
The "metal post" must be rusted in place--assume you are talking about the attachment rod that sticks up in next to the core support and secures the hold down plate? Use a screwdriver through its rounded top to force it to unscrew it, usually it works...
ABS will stay on or flicker if the voltage is off, as will the SRS system, computers you know... Doubt you "fried" anything a new battery won't be able to fix.
on
1 Post
Guess there are different fixing types?
Pierce and myself were describing the system shown on this attached link.
(scroll down to pics)
It is a correct system for a number of models and rspi's video series also covers it as I recall.
http://www.matthewsvolvosite.com/for...46198&p=226505
ohgeez, eat my own words, yer right. musta been our 850 that had the sliding block clamp, my 92 740T has the screw shaft as the battery is way far down too close to the headlight to even reach a slide clamp like I thought.
hey, both cars are volvos, both are silver or grey, both are wagons, both are turbos. ok, both are completely different under the hood, but it had been awhile.
Rusted rod screws for holding battery in place
Hey there, the rod screws (in a Volvo wagon that's been sitting still for years) are rusted over. What would you recommend I try to get this loose so I can pull the battery out? I'm trying PB Blaster...but haven't had any luck yet. Got any tips?
Nicole Lolytte Brown
12-04-2012 10:00 AM
Jeffers
11-21-2012 06:50 PM
