ABS vs Non ABS Brake Master Cylinder
Hello all. I need to replace the brake master cylinder on my 1991 240. I have the classic symptom of the pedal holding pressure for a few seconds them collapsing to the floor. I have access to a working used one which would save me a few bucks. However, this is from a car with ABS and mine is not so equipped. Can I put an ABS master cylinder on a car without ABS? I’m thinking the answer is no, but would like to be sure. Thanks everybody.
there are two different P/N's. my 240 doesn't have ABS either so I can't say what the difference is. on the parts diagrams, the ABS one has extra ports on the side, and the reservoir has a brake fluid level sensor.
8111006 for non-ABS and 8602015 for ABS (both of these numbers supersede older part numbers)
I did in fact purchase a remanufactured Ate cylinder from O’Reilley Auto Parts for $24.99 with an $8.00 core. There is a lifetime warranty on the part. It didn’t come with a new reservoir, but I was able to clean mine very well.
The bench bleeding, mounting and caliper bleeding all went well. I was gonna use a friend’s power bleeder, but I would have had to go across town to get it, and in Jacksonville, that’s quite a ride. So, I did it the old fashioned way and had my wife pump the brakes. All went well. The pedal is just right! Thanks everyone for all the info.
If you'd seen what I've seen with regards "remanufactured" brake cylinders, you wouldn't buy on ever again. I've seen unhoned, corroded bores, unhoned bores with sharp edges that cut seals, swarf in piston bores etc. Just buy new for under $100 and forget about it for another 25 years.
red8812
11-13-2012 09:38 AM
greenbluei
08-08-2012 08:32 PM
Beemer2002
01-04-2010 08:14 PM
retroguybilly
08-24-2009 08:41 AM
