B230f Crankshaft pulley torque specs 1989 740 volvo
Hello All I'm hoping to get the definitive answer here. When torguing down the front bolt on the crankshaft pulley "AKA" Harmonic damper I've read 3 different torques, 122 ft lbs from IPDauto youtube video, 170-203 ft lbs from the Haynes manual and lastly 44 ft lbs and then 60 degree turn afterwards from another poster on this Forum. The higher values are they used when using a new bolt and the lower ones when reusing the original bolt and washer or vice versa? Thanks Mike
lummert
02-22-2008 04:45 PM
