Brake Booster Replacement
Old 01-05-2006, 06:13 PM
jurteaga's Avatar
Default Brake Booster Replacement
How difficult is it to remove and replace the brake booster on my 740 gl 1989 wagon w/o ABS?
Is this a DIY task with no special tool required? My booster is leaking vacuum and causing rough idle as verified by volvo mechanic.
thank for any info.
Javier
Me512Mike (01-03-2022)
Old 01-06-2006, 12:09 AM
Default RE: Brake Booster Replacement
No special tools will take a couple of hours for you.
Do not remove the lines from the master cylinder. It will slide out of the way enough to get it out.
tech
07-28-2020 03:04 PM
tech
04-05-2017 09:57 PM
tech
07-11-2016 03:06 AM
snpklinefelter
12-22-2009 06:26 AM
NE_V70_Volvo
03-25-2009 06:32 PM
Quick Reply: Brake Booster Replacement
