brake lights
brake lights
Car=1993 240 wagon
Problem=no brake lights
I have voltage going in and back out of the brake pedal switch when it is activated as should be but no voltage to either side of the brake lights. Ran a temporary wire from the switch output directly to either brake light and they work fine.
I cannot follow the wire from the switch as it goes into a jumbo bundle of twisted wiring. There must be a split somewhere up front before sending two (left & right) wires to the back of the vehicle? Does the wire from the switch go to a junction box or any other relay or component first?
Thanks,
Arne
Thanks,
Arne
they fuse at #12 the detector itself is not fused as its simply a passthrough device
from brake light switch, blue-red wire goes to Bulb Failure Sensor (BFS) pin 9. BFS pin 10 is yellow-grey to the left brake light. pin 11 is yellow, to the right brake light, and pin 5 is brown-black to the center light.
I don't have voltage at the blue-red wire in the BFS pin 9 when I depress the brake pedal. But I have voltage at the brake pedal switch out put.
Also none of the other wire colors you reference above apply to this car. Did they change colors in different years? And further, the wire at the left brake bulb is purple but there is no purple wire at the BFS or the fuse box #7.
Any ideas? I need more help.
in this late 93 greenbook, it shows a red wire directly from the battery fuse "Y" to fuses 7-8-9-10, and a green-red wire comes from fuse 7 to the brake light switch.
in the 1992 greenbook, it shows a brown wire from the positive terminal to fuses 7-8-9-10 (actually plugged into the right-most terminal on fuse 10), then green-red from fuse 7 (middle terminal) to brake light switch pin 1, blue-red from brake light switch pin 2 to BFS pin 9, ohter colors exactly the same.
no purple wires shown anywheres I can see. yellow or yellow-grey is whats shown at the tail lights, and at the bulb-failure sensor.
OK an update. I have brake lights now but I bypassed the bulb failure sensor. I don't know if that unit is bad or not. The wire colors I spoke of are sent to the back of the car via a 24 pin connector by the drivers left foot. whit/purple for right, purple for left and brn/blk for upper center brake. So the individual brake wires are NOT sent directly from the bulb failure sensor. Blu/red to the sensor carries the hot lead from the brake switch but I don't know which wire(s) then feed the brakes but they don't match the colors you listed at all. I have ordered a new sensor.
Yes Pierce,
Those wire colors do match up after all.
Can you tell me if the right rear parking light goes thru the bulb failure sensor and if so which wire feeds the light?
Also the same question for the license plate lights. I think the BFS is out and I have one on order but it is slow in arriving and meantime I may try to bypass the above mentioned lights if in fact they travel thru the BFS too.
Thanks
Thanks
see volvo 240 Mods and Fixes
there's like 3-4 versions of the bulb failure sensor as detailedon those pages. you can cut it open, gut it, and solder up a bunch of jumpers between the pins as an alternative. for your 93, see http://www.davebarton.com/pdf/bulbfailure86-93.pdf
Resolved
The wiring problems to the back of the car were so many, it's difficult to pin point the culprits to each problem. I started out with no brake lights but pretty soon I had all kinds of problems with lights at the rear.
First-the bulb failure sensor failed and was the cause of at least a couple brake lights as well as the right tail light.
Also the rear door hinges had severed several wires on both sides of the door severed (both hinges) I had to pull the rear door and splice in new wire-quite difficult. The wire thru the hinges is definitely a weak point.
Thanks for the help. Wish I would have had that PDF of the bulb failure sensor from the get go.
Scott V
2001-2013 model year V70
07-21-2013 02:28 PM
chrystald423
03-27-2010 08:05 AM
