Check engine light reset? '94 940 Turbo
Two questions - One, is there an easy way to pull the codes on my 94 940 Turbo wagon? I have seen posts on the OBDI codes, but haven't seen much on the '94+ codes. And two, is there an easy way to reset the Check Engine light? I've corrected the problem I believe (coolant leak due to ruptured hose), but now the light is on and need to get it shut off.
Many thanks for any and all input.
--Brad
--Brad
RE: Check engine light reset? '94 940 Turbo
Is your car OBDI or OBDII? I believe it's OBDI, since generally OBDII didn't go on all cars till 1996 so the little plastic box next to the left strut tower should be how you get the code (by means of a little flashing light). And by the way, a coolant leak should not set off the CEL.
