Clutch stops halfway down, no 1st gear, second is tough - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 01-10-2010, 02:17 PM
Default Clutch stops halfway down, no 1st gear, second is tough
I just had the clutch pedal stop half way down the stroke and couldn't get 1st gear. 2nd gear was tough to engage but made it a few blocks. Then the clutch went all the way down and 1st gear was fine. A few blocks later, same thing. No 1st gear and clutch stopped half way.
Any ideas where to start my search?
Is this a hydrolic issue? Maybe fluid levels? If so, Does it need bleeding through the slave cylinder?
Thanks for any advice.
Old 01-10-2010, 03:14 PM
Default 1991 240 Wagon - Same thing!
EDIT: My clutch does go to the floor just fine. It feels totally normal.
I'm having the same problem with my 1991 240 wagon. Strangely, this only happens when someone else drives the car - even for the briefest time. It has always corrected itself - usually in an hour or so, but never in more than a day.
The other day I had it valet parked, and the valet couldn't have driven it more than 50 feet total, but it was stuck. 1st is sometimes impossible, 2nd goes with extreme force, and it seems to get progressively easier up to 4th (haven't gotten to 5th). Reverse grinds. This time it isn't "correcting itself".
I can't imagine what others are doing in such a short period of time to set this off! Why would the clutch slip only when others are driving? This sounds nuts, but the only other change in common is that they have moved the seat forward! Bizarre.
Thanks!
Old 01-10-2010, 03:17 PM
TURBO 245's Avatar
I'm guessing you have a problem with the pressure plate,kinda sounds like one of the fingers has broken off.(pic)
Also could be a problem with the clutch fork or the throw out bearing.
If you had air in the slave cylinder,it would kinda feel like stepping on a big wet sponge.The pedal would just drop to the floor,and not stop halfway.
Old 01-12-2010, 07:48 PM
Default Thanks!
Thanks TURBO 245!
The mechanic is telling me that he thinks it's bad (slipped? broken?) synchro rings. He recommends a new (used) transmission. That makes sense to me. I'll update here if I end up taking his recommendation and install one myself.
Thanks a million.
Old 01-12-2010, 08:15 PM
TURBO 245's Avatar
Does the car start moving when the pedal just comes off the floor,in the middle,or close to the top?
The way you are describing it,I would say it's time for a clutch replacement.
Dan
Old 01-13-2010, 02:21 AM
The clutch releases almost all the way at the top - like within one inch of being fully released: That's when the car moves. Just like a properly tuned clutch. Is that what you mean?
John
Old 01-15-2010, 12:36 AM
TURBO 245's Avatar
My answers were meant for the OP.(sorry for the confusion)
I read through your 1st post,and assuming that your trans is full of fluid,I'm guessing your clutch is bad.Other people driving the car is probably the biggest reason for the clutch problems.
On to post# 2
[quote] The clutch releases almost all the way at the top - like within one inch of being fully released: That's when the car moves. Just like a properly tuned clutch. Is that what you mean?[end quote]
The OP's car has a slave cylinder,and that was what I was referring to.
First thing you need to do is check for free-play in the clutch pedal.To check for free-play,lift the clutch pedal up against the pedal stop,the distance the pedal moves upward is the free-play.There should be about a 1/2" of free-play in the pedal,if there's not,it should be adjusted.
If this doesn't cure your problem,it's probably time for a clutch.
Oh almost forgot...A properly"tuned"clutch doesn't release a inch from the top,but a clutch that is worn,or miss-adjusted does.
Dan
Old 01-15-2010, 03:06 AM
I wouldn't look for a tranny yet--I agree that a clutch is probably what you need...
Old 01-15-2010, 03:40 PM
Thanks. I'll take a close look at the clutch this weekend and report back. I'll make sure it's "tuned" properly -- Doh!
Old 01-15-2010, 04:03 PM
But I'd take a look at the slave cyl. first just to eliminate is as a suspect, also since it is the easiest thing to get to... before getting into the clutch.
Old 01-15-2010, 04:14 PM
Great, I'll do that first. Thanks again!
Old 01-15-2010, 05:27 PM
TURBO 245's Avatar
240's don't have a hydraulic clutch,they use a cable.
Dan
Old 02-18-2010, 11:11 PM
Thumbs up Hello again
Hello again - sorry for the silence, but I just finished with everything today.
Dan - you were wrong about the pressure plate: It wasn't missing a tooth, it was completely broken in half! The syncros were bad as well.
All in all, I replaced:
  • The transmission (because of the syncros). The (original) drive shaft flex joint was rotting as well, so I replaced that. Luckily, I got the tranny from a junkyard for $100.
  • The flywheel.
  • The clutch.
I really can't thank you enough for all the help!
John
Thread Thread Starter Forum Replies Last Post
usb audio plays for one second then stops tauping General Volvo Chat 0 07-01-2013 11:05 AM
Towing my s60 halfway across the country sklater Volvo S60 & V60 0 04-18-2010 05:26 PM
960 sporadic rough idle, and I'm only halfway through my roadtrip!!! zmontgomery Volvo 260, 760 & 960 8 03-24-2009 12:26 AM
halfway thru pcv job..need help!!! nonsense619 Volvo 850 7 03-22-2009 11:20 PM
Dang it, I just drove 3 miles with my E-brake halfway up. quarterdimenickel Volvo 850 16 10-01-2007 10:37 PM
Tags
1st, 2nd, bad, clutch, driving, gear, half, halfway, pedal, problem, s40, s80, sound, stops, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
