Disable certain fuses to get car to start
Battery died in Volvo 240
Don't have jumper cables or a jump pack at my disposal and will have to wait a long while for someone to come help
If I disabled certain fuses - for the clock, radio, power windows, for example - would that redirect more power towards getting the car to start up without needing a jump ?
Has anyone ever tried this with a successful result ?
Thanks for your reply.
Is it true a charge pack left on the car for several hours or overnight will be better ( easier on the car, specifically the alternator ) for recharge of the battery than driving it around or idling it for 30 minutes or so ? And also the only way to bring the battery back up to being 100% fully recharged again ?
the best thing you can do is to hook up a battery charger overnight, at a 6-10 amp setting. this would, of course, require an extension cord to reach the car (or bring the battery to the charger).
I don't have much faith in those little jump start batteries, they are like 1/10th the capacity of your car battery.
The alternator is built to charge your battery and run your car while its driving
That being said, yeah it'll be easier on the car to have something else charge the battery, but it’s completely unnecessary. The issue is that batteries only last 5 or so years, the alternator can last up to 300 thousand plus miles in some cases.
basically, if the car dies while driving, bad alternator is suspect
car won’t start in the morning or after being parked, bad battery and or alternator
Either way, get them both tested
*FYI: the battery needs some amount of charge in it to be tested
chimmychong
10-15-2007 07:29 PM
