Engine starts then cuts off
Old 05-01-2007, 10:00 AM
maitresaman's Avatar
Default Engine starts then cuts off
I had an issue with my car (1990 240)starting and then cutting off. It was doing this when i started the car and when I switched into reverse. I replaced the Air Flow Meter (used) and it seemed to work just fine. Now I am having the same problem again. It just started and I think it may have to do with the warming temperatures. When the temp dropped a fews days ago, I had no problem.
Could this be the Air Flow again? What about the cold start module?
Old 05-01-2007, 02:02 PM
Default RE: Engine starts then cuts off
Have you checked to see if any codes are logged? My guess is your timing sensor is bad of which the ECU will have hopefully stored a code and will lead you to that.
Joe Redd
07-25-2020 04:37 PM
garypettengill
04-01-2014 06:39 PM
NoM54Me
11-09-2012 06:48 AM
hickdead
08-09-2009 02:12 PM
ATL_S80
05-24-2008 12:32 PM
Quick Reply: Engine starts then cuts off
