Where are the window fuses?
Old 06-15-2005, 07:22 PM
zekmoe's Avatar
Default Where are the window fuses?
My electric windows on my 93 240 just stopped running. I want to first check the fuse, but can't find the fuse box. It's really the first problem I've had with the thing since I bought it 3+ years ago. I don't know where the fuses for the window controls would be.
Thanks
Bob
Old 06-15-2005, 07:38 PM
Default RE: Where are the window fuses?
The fuse box is in the kick panel by the drivers left foot, a little door with a twist lock ****. The fuses and connectors are prone to corrosion, so you may want to remove, check, clean then re-install all of them while you are in there to prevent future problems.
Old 06-16-2005, 09:04 AM
zekmoe's Avatar
Thanks!! Found and fixed. I love the internet/
Bob
Old 03-25-2007, 06:27 PM
Default 1993 240 fuse box layout map / guide
I recently bought my 2nd 240 (favorite car of all time!) and need to go through the fuse box. Since I don't have a manual and my Haynes manual hasn't arrived yet, I need to figure out which fuse is which.
Please, help?!
Rolff
[IMG]local://upfiles/9399/C4AE312925D145A8892C8B1A58AB1571.jpg[/IMG]
Old 03-25-2007, 07:30 PM
billofdurham's Avatar
Default RE: 1993 240 fuse box layout map / guide
1 Cigarette lighter, Power mirrors, Radio, Tailgate wiper/washer 8A
2 Windshield wiper/washer, Horn 16A
3 Heater blower 25A
4 Fuel feed (in-tank) pump, HO2S heating element 8A
5 Turn signals, Tail lights, Heated mirrors 16A
7 Brake lights, Shiftlock, ABS 8A
8 Central locking, Interior and glove compartment lights, Trunk compartment lights,
Radio, Power antenna, Clock, Daytime running lights (Canada) 8A
9 Hazard warning Flashers 8A
10 Power windows 16A
11 Heated rear window, 4th gear (automatic transmission) 16A
12 Air conditioning (with blower control), Power windows (relay),
Heated rear window (relay), Seat belt reminder, Cruise control, Shiftlock 8A
13 Heated front seats, Daytime running lights - relay (Canada) 16A
14 Rear fog lights 8A
15 Parking lights (left side), License plate light 8A
16 Parking lights (right side), Instruments and control panel lights, Shift indicator light 8A
ABS-equipped vehicles: this system is protected by a separate 10A fuse located under the seat on the passenger's side.
This is from the owner's manual. You can download a copy from: http://new.volvocars.com/ownersdocs/...240_1.html#top
Old 03-25-2007, 09:16 PM
Thanks Bill!
That's going to make things a lot easier. I love driving a 240 again. The past 4 years I have had a '94 940 turbo and I liked it a lot. I kept saying that if I ever found a good late model black/black 240, that I would get it and not look back. Well it happened and I'm thrilled!
Rolff
[IMG]local://upfiles/9399/262630EBF6A146D2833B8459110E1E80.jpg[/IMG]
AR
09-26-2015 12:05 PM
BravePotato7
06-11-2006 12:54 PM
lane
04-16-2006 05:38 PM
BigBoi4Lyph
05-24-2005 12:58 AM
KNIN
04-27-2005 01:37 AM
Quick Reply: Where are the window fuses?
