HOT alternator on a COLD engine
So my 1992 944 non turbo with a Regina fuel system had been having some sluggish starts. Last night it was the worst yet and then it stalled. When i turned the key it did nothing. The battery read 12.15 volts. Charged the battery...tried again...same nothing...then one little ump and back to nothing.
Cleaned the grounds on the valve cover...cleaned the small ground from the negative battery cable to the body...sprayed the starter connections with brake cleaner and wiped them down...still nothing.
Tapped on the starter while turning the key and thought we got something...but then back to nothing.
Walked away for i don't know how long with the key in the 1 position and found that the alternator was really hot when i came back.
Any thoughts as to why the alternator would be hot. Or why the car won't start. What might be a good next step.
Thanks
Thanks
when the car is running, what voltage is the alternator putting out as measured across the battery? it should be like 13.8 to 14.1V.
the little grounds you cleaned won't affect the starter or charging circuit, you need to clean the BIG grounds (engine block to chassis, alternator to engine block, battery to chassis) and power wires (battery + to starter, starter to alternator +)
I'm guessing you have a bad battery or bad grounds/wiring, but guessing isn't reliable.
I woudl be in there with a volt meter, measuring the battery voltage before and during 'start' (have a friend turn the key). if the voltage is dropping below 9V, your battery is bad.
If the battery voltage ISNT dropping, then I would be measuring voltage from the battery - to the starter body/ground, if you see any there when its switched to 'start', then that ground path is bad. try battery - to chassis, and chassis to starter body, each time having someone switch the starter on. more than 1V on any of those, bad ground on that leg.
Ok the hot alternator means nothing...i got a helper and did those tests...there was no voltage present at any off those tests...i connected a jumper wire from the battery + to the spade terminal on the starter solenoid and nothing happened...the battery is good...so i guess it's time to pull the starter...it's only got 315,000k on it.
elbert
10-18-2011 10:54 AM
