11-10-2008, 08:45 AM
Idle Air Control Valve Symptoms?
I am under the impressoin my Idle Air Control Valve is causing my issues, and wanted more opinions.
If the car is started when it is cold outside, it will idle lower and lower until it dies. It takes multiple starts to get it going. When warm out, it starts fine.
After being driven a while, when in park or neutral, the idle is high. Considerably higher than when first started.
I can unplug the Idle Air Control Valve, and the car doen't change idle or anything. Everything operates as it did when it was plugged in before.
MAF/AMM checks out ok, as does oxygen sensor. Fuel pressure regulator seems fine too. Throttle body is clean and the car has a new flame trap and vacuum lines with no leaks as far as I can tell. Throttle Position Switch adjusted correctly, but hasn't been checked electrically yet.
I have the following codes:
2-2-1
2-3-1
Is the Idle Air Control valve causing all this by being stuck wide open at all times? Could it be letting too much unmetered air into the engine causing rough cold starts, and enrichment of the fuel mixture, activating fault codes?
Thanks for the opinions in advance!
__________________
'93 Volvo 240 Sedan
11-10-2008, 12:35 PM
RE: Idle Air Control Valve Symptoms?
Is the throttle switch adjusted properly?
__________________
1987 Ford mustang LX Coupe 5.0
1995 Yellow T5-RM running
1996 850 turbo
1994 N/A 5-speed wagon Purple (daughters)
11-10-2008, 01:01 PM
Yes.
__________________
'93 Volvo 240 Sedan
11-10-2008, 02:03 PM
Then maybe the idle motor is dead.
When the car is running when you go from drive to park the idle shoud go up about 300 RPM for a few seconds then drop down to about 800.
__________________
1996 850 turbo
11-10-2008, 05:47 PM
Well, I unhooked the hoses to the Idle Air Control Valve, but left it plugged in. I turned the ignition on, sending 12v through the connector, into the valve. Nothing happened. I unplugged the valve from the connector. Nothing happened. I guess it's dead. How does the IAC get it's voltage? Where from? I am understanding that with voltage applied, it should open, and snap nearly closed when voltage is removed. That being the case, it appears to be stuck closed. OHM readings on the valve were good, at 8.2.
__________________
'93 Volvo 240 Sedan
11-10-2008, 08:16 PM
It gets signal to active from the throttle switch.Thats why I asked if it was adjusted correctly.
You hear a click when you just darely move the throttle?
__________________
1996 850 turbo
11-10-2008, 08:40 PM
OK...here's the simple answer. The IAC, as you probably know, only affects idle. When the throttle blade is open to any degree, the IAC has no effect. You are describing a textbook dead IAC. Yes, your Throttle Position Sensor needs to be adjusted correctly. You should pull your TB every third oil change or even more often and clean it thoroughly IMHO. As previously described, hold the TB to your ear and you should hear a distinct click just as the throttle blade moves. If you don't hear it, loosen the allen screws and try to adjust it so it does click just as the blade opens. After you feel comfortable the TPS is correctly adjusted try this. After the car is good and warmed up and idling too fast....take a pair of vise grips and clamp off the hose (either one) on the IAC and see if idle drops as you clamp harder. The ideal tool for this is a hose clamp pliers but vise grips will do if your hoses are in good shape. Assuming your idle drops, you may conclude your IAC is ill if not dead. I've had some success cleaning the IAC w/ carb cleaner and getting the crud out; early ones can actually be disassembled to be cleaned while later ones are pretty much sealed units. If cleaning doesn't work, make sure your contacts are clean and unbent on the plug. If every thing looks good, call Nick at fcpgroton.com (No I'm not a shill, Nick knows his Volvos and they have low prices on IAC's) because the IAC is dead most likely. There is an outside chance the idle circuit on your ecu is toast but go w/ the IAC first.
11-10-2008, 09:02 PM
Quote:
ORIGINAL: swiftjustice44
Just to ask about this statement. Do you mean if the idle doesn't change the motor is dead?
Because the motor is supposed to stall if the hose is pinched while at idle. If the idle doesn't change the idle motor isn't working.
__________________
1996 850 turbo
11-11-2008, 07:46 AM
I'll try the hose thing today.
The TPS is adjusted correctly.
With the ignition on I get 12v at the IAC connector, is that supposed to change when I open the throttle? Will the car have to be running for it to change? Thanks.
__________________
'93 Volvo 240 Sedan
11-11-2008, 08:47 AM
Yes when you first move the throttle that should cut the voltage. The idle motor turns off when the throttle is moved the slightest bit.
You should be able to test without the car running.
__________________
1996 850 turbo
Tags
2004, 240, 50, 940, air, c70, control, iac, idle, location, motor, mustang, symptoms, valve, voltage, volvo  |
| Thread Tools |
Search this Thread |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
