wet or dry? opinions.
Old 05-25-2007, 12:41 AM
VolvoDriver's Avatar
Default wet or dry? opinions.
When doing the timing belt and replacing the sprocket seals, is it necessary to drain engineoil?
Old 05-25-2007, 02:05 AM
tedv's Avatar
Default RE: wet or dry? opinions.
Necessary? No...
Old 05-25-2007, 09:59 AM
...but probably a good idea? wouldn't the oil spill out???
Old 05-25-2007, 10:36 AM
tedv's Avatar
For the timing belt change, no, it'd not spill out... And while I am not sure about which "sproket seals" you are reffering to, the oil stays in the oil pan and shouldn't spill out if any work is done above its level. But, since you are at it and getting dirty, if it at all needs the change, well, then do it!
Old 05-25-2007, 10:51 AM
thanks for the reply,
I speak of the engine oil seals, cam, layshaft, crank.
klart
06-07-2011 06:53 AM
rspi
06-06-2011 04:44 PM
jstecher2010
01-19-2010 03:12 PM
livelychick
05-19-2009 09:54 PM
Beardog
10-09-2007 02:26 AM
Quick Reply: wet or dry? opinions.
