interchangeability of 93 240 sedan->90 240 dl wagon- SPEEDOMETER CLUSTER, etc?
Speedo-transplant
No on the speedo, 91 on were ABS and SRS models. The instrument cluster circuit boards are different because of this. Seats are the same problem because of SRS. The seats may appear the same but the seat belt wiring is different. Look for pre 91 models with out ABS and SRS for theses items. Wiper motor is good. Hope this helps you.
on the 740/940/960 seats, at least, you can just swap the seatbelt latch and wire harness between versions. ditto the single reel vs double reel seatbelts, they bolt on the same place, just swap the seatbelts and trim between versions. I have 1998 S90 seats in my 1992 745T...
now, I dunno if the 240 seats are the same way with regards to this, but I wouldn't be surprised.
zloetakoe
05-28-2011 07:29 PM
studbike
08-01-2010 04:48 PM
