LH2.2 from 86 240 on an Alfa Spider
#22
#23
Hey Pierce, have you ever notice that red wire that's coming from the 25A fuse getting sheered? Not the one coming from the battery but the one coming from the fuse to the ECU.
I've found 2 completely different harnesses, an 85 244 and an 87 244, both had a sheer in that wire causing shorts with the frame. The sheer itself looks professional, as if someone actually cut off the rubber. It's quite hidden too, so hidden it would be impossible for a human to do it, as it butts against the chassis perfectly. I don't know where I put them or I'd take a pic to show you.
But yeh, OP make sure that wire doesn't have a sheer in it, or that fuse will continue to pop.
#24
ok.getting closer
Changed relays , got 12volt to the fuse and relay ( big red wire, ) but the fuse blows during cranking any ideas? and a note. Bosch lh fuel injection 2.2 is not volvo only Saabs and Audi used the same system so having it on my alfa Romeo spider should not make any difference . lots of bmw folks stuff it there 2002 cars
#25
#26
what sort of fuel pump(s) are you using? how are they being powered ? The volvo used two fuel pumps, a low pressure in-tank transfer pump, and a high pressure main pump under the car... both were powered off the yellow-red wire off your '4-wire' connector. you can actually replace all of this with a single in-tank high pressure pump from a later volvo or similar LH car, such as a Volvo 850
the LH 2.2 fuel pressure regulator maintains about 36 PSI relative to manifold vacuum, so you need a main pump that can maintain somewhat over 36psi while delivering sufficient fuel for the engine at full boil (wide open throttle near red line).
do note, that while many other cars use Bosch LH 2.2, the ECU's are programmed for the specific motor and its fuel-air requirements at the range of RPMs and throttle loads. I'm guessing the alfa motor is somewhat smaller than 2.3L and probably has a somewhat higher redline.
#27
It was running perfectly infill a few days ago allways started and ran even the mpg went up.very happy with it, then a few days ago o stopped at the store got back in no start . if you look at the volvo ,1986'schematic you will notice that the entire Lh jet has a small separate harmed, I am not underestimated the knowledge here, yes the alfa motor has a higher red line, I have hit the stock fuel cutoff but on as rolling road to test the mixture ratio and it was great. I will remove the harness from the car and cut it open to check for problems, as it was driving great until a few days ago
#29
#30
#33
#34
ok, took out the harness,removed the covering to check for any broken wire's or bad solder joints,none, next checked continuity of each wire from plug (sensor) to main sci plug ,no problems. I am thinking bad ground to the motor. what cconfusing I'd that I can set the key to run for 5minutes,and fuse is ok, but as soon as I start the car,the fuse blows still thinking bad of loose ground causing the fuse to blow,an
#36
a loose ground is very unlikely to blow a fuse.
blowing a fuse usually means a 'hot' wire is touching ground. the only circuits that are powered when the car is cranking/running and unpowered when its turned on but not running are the yellow-red wire circuits, which include
with car switched off, unplug your fuel pump relay, and hook up a multimeter in "OHMS" mode between chassis ground and fuel pump relay socket pin 87/2 (yellow-red wire). if you see 0.5 ohms or less, you probably have a problem. 0 ohms would be a hard short. unplug the idle air valve, repeat same test. plug that back in, unplug the o2 sensor, measure ohms again. do this for each injector, too.
what did you connect that yellow-red wire on the 4-pin plug off the ECU to? it should be no-connection, since your fuel pumps are being powered elsewhere (OR you should hook your fuel pump(s) up here instead, the way they are meant to be).
- fuel pumps (but you said yours are powered externally)
- injectors
- idle air valve (this uses a brown wire thats connected to the yellow-reds at a junction in the harness)
- O2 sensor heater
#37
