M47: reverse grinds/1st & 2nd hard to engage
Old 07-17-2010, 10:48 PM
underaroof's Avatar
Default M47: reverse grinds/1st & 2nd hard to engage
Hey everyone,
So I have an 89' 240 DL with a M47 5-speed. The only problem I have with it is that sometimes it's basically impossible to get into 1st or 2nd gear from a standstill unless I put it in 3rd or 4th before trying 1st or 2nd again. The reverse gear grinds maybe 90% of the time trying to get it in, but it goes in without a problem when the engine's off.
I've adjusted the clutch cable at the fork, adjusted the reverse lockout plate, and replaced the transmission fluid.
So what my real question is, how can I be sure this is a problem related only to the clutch and not the gearbox? I'm sure the clutch could probably use a replacement, but I don't want to get done with that to find out it's the gears that are bad..
Old 07-18-2010, 12:09 AM
tedv's Avatar
You need a clutch disc replacement. If you keep postponing it, you will damage the gears.
Old 04-26-2012, 03:58 PM
justin1972's Avatar
I have exactly the same issue with my 91 240 with m47 tranny. It works perfectly when cool, but becomes hard to get into 1st and reverse grinds after driving it for awhile.
I've adjusted the clutch and changed out the oil with synthetic and it got better, but the issue is still there. Did you resolve the issue with a clutch change or was it the transmission that had to be rebuilt?
I don't want to change the clutch only to find out that the transmission was what needed to be rebuilt.
Thanks in advance!
Old 04-27-2012, 02:28 AM
Titan Joe's Avatar
I'm going to make a few assumptions here to explain a few things about shifting technique. I think if you do that, it will make things shift easily.
Assuming that the clutch has been adjusted properly:
First, reverse is not synchronized and will always make a little noise going into reverse. To minimize it, come to a stop before shifting. If you are moving at all, a new M47 will grind the same.
Second, I guessing that you have two hard shift scenarios, the first being when you are completely stopped and trying to put the car in gear, like at a stop light. If you hold the clutch in for a long time and have the car in neutral, the transmission will come to a stop. The gears will not be spinning so the teeth will not be able to line up allowing you to shift into gear. The get it to shift, let the clutch out in neutral then put it back in (this spins the gears) and then try putting it in first.
The other shifting scenario is when you are coasting but you are still moving and you go to put it in a low gear and it doesn't really want to go in. This is normal for worn out syncros, but if you double clutch, you make it work fine. What's happening here is that the gears are spinning at really different speeds and the syncros are worn out, so they don't match them up. For example, if you go to put the car into first at 10mph, it may not seem like much, but the matching engine speed for that gear's speed is around 2000rpm. If the engine is idling (850rpm) there is a pretty big difference. You can match the gears yourself. Let out the clutch in neutral and blip the throttle. You just do it to speed the engine (and the input shaft of the transmission) up to the matching 2000-ish rpm. Then put the clutch in and pop it in gear. You do the same thing with second gear, put scale the engine speed back. You don't have to perfect top get it. This double clutching technique is how truckers are able to shift without using the clutch. They match it themselves.
If your transmission had damage, it would whine in certain gears or pop out of gear due to excessive wear. If it does not do those things, the gears and teeth should be in good shape. It just sounds like years of making the syncros doing all the matching have taken it's toll. They have on my car, but a little advanced shifting technique will make for smooth problem free shifts. And you can impress your friends.
Old 04-27-2012, 09:42 AM
justin1972's Avatar
thanks Joe for taking the time to explain different ways to shift. Both of your suggestions do not make a difference in shifting.
What I've been doing to get into 1st after the car is started and rolling is to apply slight pressure into 1st as the car comes to a stop with the clutch in. If I don't do this while the car is slowing down it is very hard to put into 1st...even with your suggestion of "let the clutch out in neutral then put it back in (this spins the gears) and then try putting it in first".
As for reverse...it will grind no matter how long the car is not moving (clutch in, motor running). Even if I put it into 1st prior it still grinds. If I need to reverse I put it into gear with the motor off. Not being able to reverse easily is the real issue that makes me want to deal with the problem.
From reading other posts here of others with similar issues I would conclude that it is not a worn syncro/gears as the problem extends to the reverse gear that is not syncronized.
I also read a post on the same issue with the M46. I know it's a different transmission, but most pointed to clutch adjustment, release fork and clutch parts/pilot bearings:
740 m46: grinding into reverse, hard shift into 1st. Help! - Turbobricks Forums
Something is not disengaging properly with the clutch in and allowing gears to continue to spin more than usual. Am I correct in thinking this? Is it possible that it's something other than the syncro gears?
Thanks in advance!
Old 04-28-2012, 03:12 AM
Titan Joe's Avatar
Hmmm, then I thought that you adjusted the clutch. It sounds like your clutch is adjusted improperly. It's not completely disengaging the motor from the transmission. I'm not familiar with the adjustment of the cable clutch in a 240, but I would say that there is either too much end play in the cable or something (like a floor mat) is blocking the full movement of the clutch pedal.
As a note, from what I understand the M46 and M47 are very similar, but overdrive is just another gear inside the transmission rather than a separate unit. The ratios are exactly the same (except overdrive, the M46 has a slightly taller ratio).
Old 04-29-2012, 03:47 AM
underaroof's Avatar
Well, considering this thread is almost 2 years old I guess I should've fixed my problem by now right?
I haven't done anything to the car besides routine maintenance and it still runs like a champ, besides the squealing release bearing and the tough shift into 1st.
Your description of trying to get into 1st gear when stopped exactly explains my problem. I can get into 1st just fine if the car is rolling, but when I stop fully, it's damn near impossible to get into 1st without running the transmission through 3rd or 4th. I guess I've just gotten into the habit of shifting 3 times every time I stop. With reverse I have to run it through 3rd and 4th too, but it works fine after that.
Anyway my problem is still there, and I'm pretty sure it's the pilot bearing; it's been screaming at me here and there. I wasn't sure if replacing it would actually fix it, seemed more like a gearbox thing to me, but your research seems to make it so. I wish I would've been able to help with definite answer, but I guess life would be a lot easier for both of us if we just got in the garage and did it.
Old 04-29-2012, 09:43 AM
justin1972's Avatar
Thanks for your response!
So you've lived with it for some time now? wow! I've done so for 6 months and it's next to impossible to get into reverse unless I do so before starting the car. This has become quite annoying so I decided to bite the bullet and have my mechanic change out the clutch and related bearings yesterday. Even he thought it was the gears in the transmission.
This was a hard decision as the clutch was not slipping and worked fine otherwise.
When he opened everything up the bearings did not appear to be abnormally worn. The pressure plate had some wear, but he said that it was not too bad. Everything back together and the transmission is working like new! No grinding into reverse or hard shifts into 1st from a stop
So I would guess, just as you have, that the problem would be fixed with new clutch parts.
Thanks again for everyone's help!
Old 09-05-2013, 04:01 PM
kablunak's Avatar
Hi, I have a similar problem with M47 (1991 240). First gear is semi-hard to engage. From a cold start, no problem, as the car warms up, it gets more difficult, after highway or much city driving I have to go to 3rd or 4th first in order to get the 1st in. At the stop light I go into neutral, let go of the clutch and wait for green. Then depress the clutch and try to engage 1st. Whatever can be adjusted externally has been adjusted by Volvo mechanic a couple of weeks ago, but the problem is back. No problems with the other gears, including reverse and there are no noises coming from the tranny. Your suggestions are much appreciated.
Old 09-06-2013, 08:45 AM
justin1972's Avatar
I finally got around to changing the clutch and throw out bearing and it was what was causing the problem. The car is shifting like new!
Thanks for all your help!
Old 09-06-2013, 09:35 AM
underaroof's Avatar
This was exactly my problem, the throwout bearing in my car was completely blown apart, no grease to be found whatsoever. It was bone dry and stuck together so when I was on the clutch it wasn't letting the gears spin freely in neutral. I had a hard time getting the bearing out of there but I worked it loose and ever since I changed the various clutch parts I haven't had to touch the transmission, it goes into 1st while stopped with no problems anymore. If the clutch on your car hasn't been replaced in a [long] while or at least taken apart to be looked at, this could be your problem. I knew that my 240s transmission wasn't working right, and once I found the problem it turned into the car I thought it always should have been.
Hope this helps, and thanks for all the replys guys.
AnEskimo
07-12-2013 11:38 PM
danielcash
08-27-2010 10:44 PM
denver005
07-17-2009 07:43 PM
codmac
04-12-2009 04:10 PM
V70XC1999INCT
11-04-2007 07:29 PM
Quick Reply: M47: reverse grinds/1st & 2nd hard to engage
