Need Help Identifying A hose attached to EGR valve.
Old 05-30-2012, 02:43 PM
cyrusyn's Avatar
Default Need Help Identifying A hose attached to EGR valve.
1991 Volvo 740 Turbo
200K miles
Hi,
I was examining EGR valve and found a huge crack on a tube that stems out from the head of the EGR valve and goes into the EGR vacuum controller. I need to find out what this tube with steel core is called so that I could order new one at a dealer. Or can I get this from Autozone or Pepboys too?
Old 05-31-2012, 01:35 PM
you could use generic 'braided vacuum/fuel hose' of the right diameter, my 1992 745T has 9.5mm OD, 5mm ID hose on the EGR. I'd get enough to replace ALL your vacuum lines, if one is cracked, the rest aren't far behind...
epic.rsm
06-06-2014 11:49 PM
rjb44
04-23-2011 11:32 AM
rkent777
04-16-2008 06:52 PM
ludeless
03-02-2006 01:11 AM
Quick Reply: Need Help Identifying A hose attached to EGR valve.
