Performance chip?
Old 09-16-2016, 04:24 PM
beleive's Avatar
Default Performance chip?
I noticed a few computer performance enhanced products for Volvo 240. Has anybody had any experience with them? Im looking for a little more Lowend power. I have non turbo 90 5 speed. Thanks
Old 09-17-2016, 01:05 AM
no chip will give you more power on its own, you need to do engine work, and increase the amount of air it ingests, then you can squirt in more fuel and get more power. probably the easiest upgrade is a turbo swap from a 740/940 turbo. best engines to use as a jumping off point to more power are probably the 94-95 b230ft that have piston skirt oil jets. those are 160HP and 200 ft-lbs stock, and they have strong torque way down low. they are relatively easy to turn into 250HP fire breathers. more horsepower than that gets way more expensive as you'll be blowing transmissions and rear ends.
AFAIK, volvo never used the M90 5-speed with a turbocharger, they felt it wasn't strong enough for the turbos torque, so they used the 4-speed w/ an OD for the older turbo 240's.
Old 09-17-2016, 10:16 AM
beleive's Avatar
kinda what I thought. An engine would have to be way out of tune to gain 50 hp like they claim. LOL. Thanks for the info. I appreciate it.
Old 09-17-2016, 03:17 PM
tryingbe's Avatar
Makes your wallet lighter so your car can go faster.
Old 09-19-2016, 09:45 AM
lev's Avatar
lev
lev is offline
The easiest way to gain some HP in these cars is to swap in a VX or a T cam, very simple and quick, gives you some 15 extra HP...
Chipping an old Volvo, I don't know, the Turbo+ package in the late '80s 740s gave 20 extra HP, with some minor mods...
As far as chips in general, in the newer cars they can do wonders with some minor mods, even without: the VW turbos, Passats, GTIs, etc. can go from 130-150 hp to 225 without too much work. (The Audi TT has 225hp with the same 1.8 motor the 130hp Passat has).
Old 09-19-2016, 12:59 PM
the T+ package allowed 30 seconds(?) of overboost at max RPM, max throttle
those Vx cams, don't they give you more high end HP at the expense of low end torque?
ron1
03-22-2008 09:46 PM
dpallen
03-16-2008 12:29 PM
mhovis
03-14-2008 04:23 AM
tanjung66
03-11-2008 12:16 PM
dark_realm
02-06-2008 10:29 AM
Quick Reply: Performance chip?
