rear light problems!
Old 02-17-2014, 05:55 PM
Tim Garvie-Maclean's Avatar
Default rear light problems!
I'm having a bunch of problems with my rear light assembly. It's bad enough that I don't want to drive on it because it would confuse other drivers.
I made a 3 minute video of the problems, because it it's harder to explain it via text.
Old 02-18-2014, 11:19 AM
fochs's Avatar
Default Can't see video
Old 02-18-2014, 11:42 AM
fochs's Avatar
Really goofy things can occur with lighting when there is a incorrect bulb anywhere in the system. For your wagon:
Front top is: 21 W BA15S
Front bottom is: 5 W BA15S
Rear top 3 bulbs are: 21 W BA15S
Rear bottom bulb is: 21/5 W BAY15d
Check those first and clean up any ground connections you come across.
Old 02-24-2014, 05:27 AM
SevenTease's Avatar
The videos say they are "private." This seems to have more about the bulbs fochs talks about. http://www.matthewsvolvosite.com/the...ulb-guide.html
Old 02-24-2014, 02:32 PM
240-FAN's Avatar
I can't see the videos either. You should also take a look at the solder points in the light circuit boards. Mine were corroded and causing trouble when I got my 91 244.
Old 02-25-2014, 03:36 AM
Sorry, I didn't realize that my video was set to private. I fixed that. You should be able to see it now.
Old 02-25-2014, 06:12 AM
240-FAN's Avatar
Check for the soldering on the boards at both light assemblies. Also, check the bulb failure relay circuit. I had similar problems - except in my case lights would randomly stop working (bulbs would be fine).
Nice wagon though!
Old 02-25-2014, 02:53 PM
I went to ipdusa.com to get the bulbs listed, but IPD says that they don't fit my specific model. Looking back, i noticed that I didn't list my specific model, though I don't think it matters all that much. The car is a 1985 VOLVO 240 NON-TURBO 200 5 DR WAGON B230 FRWD AW70 LH 2.2
I'm heading out later tonight and I might as well hit up an auto part shop to pick up a whole new set of lights (they're cheap and handy to have extras). Will the ones that fochs listed work, or are they for a different model? I don't have my manual on me to verify, nor am I near the wagon.
Old 02-25-2014, 03:29 PM
fochs's Avatar
Those are the bulbs listed in my Bentley manual as well as in my 1983 owners manual.
Old 02-26-2014, 04:10 PM
The only way that I can tell them apart is that the top 3 have either 1156 or 1157 written on them. What is the bottom one supposed to have?
Old 02-26-2014, 05:58 PM
Disregard my last post. I went to O'Rielley's and got the proper 21/5 W BAY15d, which is basically a 1157 bulb. Popped them in, no change.
The guy helping me said that it might be my turn signal arm going bad. He told me that when I turn, the turn signal should automatically turn off. I did not even think of this because the car is so old. On the way home, I noticed that when I turn right and then straighten out, the turn signal turns off on it's own, like it is supposed to. However, when I turn left, it does not turn off like it should.
I'm not an expert by any means, but I think that since most of the lights stay on on the left side, that this might be the problem.
Any second opinions?
Old 02-26-2014, 07:22 PM
1156, 1157 are NEVER the right bulbs for any euro application. never use any brass base bulbs, the correct bulbs have chrome bases.
someone just published this very handy cross reference list on a motorcycle forum, this applies to all euro cars. the 'osram' numbers are available here as Sylvania "OEM" type, either green or red hang cards at your local parts store.
so, your 21W BA15S are Sylvania 7506. the 5W BA15S is a 5007, and the 21/5W is a 7528. The 11xx series brass base bulbs are for old american cars, the euro sockets are made from different metals and the brass bases will corrode badly.
Code:
Osram ECE     Base       Location
2721  W1.2W   W2x4.6d    Gauges, ~5mm dia bulb
2821  W3W     W2.1x9.5d  Gauges, ~10mm dia bulb
2825  W5W     W2.1x9.5d  (not for Airheads, too hot)
2827  WY5W     W2.1x9.5d (not for Airheads, AMBER marker)
3893  T4W     BA9s       Parklight (& GS gauge)
3898  ---     BA7s       Clock/Volt & /5 (aka A-1272)
5007  R5W     BA15s      Tail Light
7506  P21W    BA15s      Turn or Brake
7507  PY21W   BAU15s     (not for Airheads, AMBER Turn)
7528  P21/5W  BAY15d     Brake+Tail
7951  R2      P45t-41    45/40w Headlight (/5)
9003  H4      P43t-38    60/55w Headlight (aka HB2)
Old 02-27-2014, 03:00 AM
I bought the proper European bulbs, and chucked out the 1156 and 1157 bulbs that the previous owner had put in. Probably should have specified that.
Old 02-27-2014, 07:16 AM
SevenTease's Avatar
Some wagons over the years also use these. The base pins are different than most. Seems most have that ECE label stamped right into the factory socket somewhere if you look for it.
P21/4W
BAZ15d
7225
Old 02-27-2014, 10:33 AM
Any chance that it could be the turn signal arm going bad?
Old 02-27-2014, 10:57 AM
sure, could be that, or really most anything I'd be in there with a volt meter and the wiring diagrams, testing things.
  #17
Old 02-27-2014, 03:52 PM
There was a wire that the previous owner had cut under the jumpseat and put back together with connectors. It wasn't making full contact. Fixed the connection, now everything is working fine.
  #18
Old 04-17-2014, 08:23 PM
wilfuller02's Avatar
from an electrical point of view the work like that because there is a shared ground for the directionals it is touching most likely on the driver side as that is were the main tail lights wires usually are but find were and what side in the rear and check the grounds not crossed with a your other power in that junction or between the two
nealeas
03-24-2018 09:59 AM
commoncold
07-22-2014 05:41 PM
s80kid
01-22-2011 11:12 AM
ErnstlS90
10-23-2008 08:37 AM
team
11-26-2007 09:28 PM
Quick Reply: rear light problems!
