Replacement headlight lens? or assembly?
Old 01-17-2017, 07:28 PM
wakdady's Avatar
Default Replacement headlight lens? or assembly?
Hi all, first post here!
I just picked up a 92 940T and the driver headlamp is cracked, so it won't pass safety inspection. However, it has the fog light option and everything I find is for cars without fog lights.
Am I missing something? I don't even see how to remove the square lamp separately.
Old 01-19-2017, 04:06 AM
drivers headlight lens+reflector assembly for the w/ fog version is volvo PN 1358540, ouch, about $400, and I am not sure Depo makes an aftermarket one (they do for the non-fog configuration, but changing from one to the other requires a new grill, new turn signals, new under-headlight-trim, hardly worth it). the parts drawing may give you hints as to how to remove it, I think I would remove the whole assembly then take it apart
thats from here, Volvo Headlights Headlamp with fog lamp. 940, 960 -1994.
Old 01-20-2017, 12:24 PM
wakdady's Avatar
eek. that's a lot!
Old 01-20-2017, 12:48 PM
your best bet will be a junkyard, I suspect. any 91-95 940 with the fogs (most upscale ones had them) or 92-93 960 (94+ 960's had a facelift that is incompatible)
shoeboxOH
02-26-2017 12:34 PM
madymo3d
07-22-2013 07:53 AM
cb1313
05-23-2009 11:49 AM
GolfGuyatWork
05-22-2008 03:29 PM
mnvolvo
04-07-2008 10:27 AM
Quick Reply: Replacement headlight lens? or assembly?
