Replacing Mechanical Cooling Fan
Just for fun...Has anyone successfully replaced the mechanical fan/fan clutch with an electric fan and relay? I grabbed an electric fan, shroud and two speed relay from a 1992 960 on 50% off day at Pick N Pull. I'm not too sure about the health of the fan clutch in my 1987 740 NA. The price of a new fan clutch has swayed me into thinking about putting in an electric Volvo unit.
OR
How about a Flex-A-Lite fan?
OR
It can be done pretty easy, I had a 67 firechicken with a 400cc engine that did not want to keep cool, I put an after market electric fan on it instead of the clutch fan and it cooled her down by about 20 deg. The fan I got had an inline thermostat that you could adjust to come on at the temp you want and would shut down only after the temp got back into the range I adjusted it to. You will also find that the electric fan does nor rob MPG's OR HP's, although not a big difference.
