Replacing Timing Belt '86 240
Making progress on my 240 wagon. Replaced all the calipers and disks, last year the torque limiter bushings.
I'm about to take a long trip back to New Mexico from Oregon. The manual says the timing belt should be replaced every 50,000. I have no idea when it was last replaced. The book also says that SOME engines will actually be damaged if the belt brakes while driving (when else would it break?). So - I'm taking a new belt along for the trip. WIll the 240 be damaged if it breaks? Any tips on replacing?
never heard of a US b230f/ft being damaged by a broken timing belt. its the 16 valve b234f used on some 740/940's that is subject to collisions. european high compression b230E engines, possibly too.
the timing belt is a 60K mile item. pop the upper cover off and inspect it. if its old worn cracked, time to replace. its not a job I'd want to do on the side of a dark lonely road at night.
fear not, it's an easy job. the timing belt in my 89 240 gl broke this morning.
by 2 pm i had time to tackle it. i am a small engine mechanic by trade so i have air tools and an electric impact.. the impact wouldnt work to take off the crank pulley bolt. no problem . i cut a 4 foot peice of lawnmower starter rope and stuffed it into #1. bolt came right off with breaker bar. the new gates belt has marks on it , and the ones on the cam and distributor gears were easy to find, the one on the crank ... not so much , but if you set the crank at tdc before removing the bottom cover and leave it alone during the process you ought to be fine. total time from hood up to test start was about 1 hr 15 minutes. add 30 minutes for putting the cover the belts fan and shroud back on .. done .. god.. i love these cars. I'm getting a 740 turbo wagon Wednesday and i'll be replacing that timing belt asap .
phaedrider - thanks for your encouraging and detailed post. Two hours is pretty good time considering - I wonder if you took off the radiator and the fan - that's what takes me so much time - is the little bolts on the fan using a tiny wrench. But what does " i cut a 4 foot peice of lawnmower starter rope and stuffed it into #1" mean? #1 cylinder? That can't be right. I'm sure you're telling me how to hold the pulley still while taking off the crank bolt - can you elaborate on that? Thanks! : )
