1989 240 DL won't shift into 4th gear.
Old Feb 23, 2009 | 05:34 PM
89240DL's Avatar
Smile 1989 240 DL won't shift into 4th gear.
This morning on the highway cruising at 75 mph I noticed my 240 seemed to downshift on its own. There was no noticeable loss of power, just higher RPM's it seemed. I checked the tranny fluid later on at work and the fluid level is good, smells ok, good color. The vehicle has about 200K miles on it. On the way home it will not shift into 4th gear. Could it be something simple like the overdrive solenoid or relay? Thanks in advance for any suggestions.
Old Feb 23, 2009 | 11:43 PM
blue goose's Avatar
Did you check fuse #11?
Old Feb 25, 2009 | 02:51 AM
89240DL's Avatar
Yeah, it's not blown. I can hear the relay clicking when I cycle the O/D switch on the shifter too.
Old Feb 25, 2009 | 03:26 PM
blue goose's Avatar
IPD has an OD solenoid bypass kit. With that you will not be able to take it out of OD manually.
http://www.ipdusa.com/product.asp?st...hStartRecord=1
Old Feb 25, 2009 | 10:49 PM
89240DL's Avatar
Thanks blue goose! I just ordered the bypass kit. Has great reviews on IPD. I was almost gonna order a new solenoid but, I never shut off the overdrive anyway. Might as well install the bypass. Lookin forward to installing the kit and seeing if my troubles go away!
Old Mar 15, 2009 | 02:00 PM
89240DL's Avatar
Again, thanks blue goose! FINALLY had a chance to install the bypass kit. And......it worked! It's been so cold up here in Upstate NY. Had a beautiful sunny day today to do it.
Old Mar 15, 2009 | 10:32 PM
blue goose's Avatar
Glad it worked out for you.
elchingon2002
Jul 22, 2014 06:09 PM
Dainos
Apr 18, 2010 01:04 PM
act1292
Jan 6, 2010 12:54 AM
Dainos
Sep 11, 2009 09:17 PM
Vee
Jan 13, 2009 06:05 PM
