shudder when decelerating
Old 04-10-2007, 03:36 PM
gerbs's Avatar
Default shudder when decelerating
Hopefully someone has successfully dealt with this one. 1989, 240, 5 sp. manual, ~150k miles.
When slowing down, with or without brakes, the car begins to shudder as speed dips below 25mph. Shudder increases as speed decreases. Can be felt throughout car and is very apparent below10 mph all the way to 0 mph.
Does not occur during acceleration, and shudder goes away if I accelerate without coming to a stop. Shudder is not present if speeed is above 25mph. At freeway speeds all seems normal.
Does not seem to be brakes since it happens whether or not I am on the brakes. Also, there is very little vibration transmitted through pedal other than what seems incidental, same for steering wheel.
My thought is either rear wheel bearings or driveshaft. Any thought on other possibilities or how totroubleshoot and diagnose?
Thanks in advance.
Old 04-11-2007, 01:19 AM
TedH's Avatar
Default RE: shudder when decelerating
can you feel it in the shifter ****? sounds like somthing with the drive line...mabey bad u-joints. or a tranny mount.
Old 04-11-2007, 12:07 PM
gerbs's Avatar
Ted,
The shudder does not noticeably transmit through the shifter ****. However, since you mention it, I will take the car out for a drive during lunch and be more certain. Mostly it seems to come through the body of the car in general, I feel it much morethrough the seat and in floor.
Thanks.
Old 04-11-2007, 04:42 PM
gerbs's Avatar
I took the old beast for a slow run around the block paying close attention for any abnormal vibrations coming through the stick, none. In fact the vibration seems to generally be throughout the car EXCEPT the stick.
Does this rule out the driveshaft/carrier bearings?
Does this instead put the spotlight on wheel bearings?
Thanks.
Old 04-13-2007, 06:02 PM
Sounds like thedriveshaft...... u joint or center bearing
Old 04-17-2007, 01:10 PM
gerbs's Avatar
Yeah, I think you're right. The shudder has subsided for the most part, only to be replaced with a light metallic *****.................*****............*****....ch ink..*****.chinkas I accelerate up to about 25mph. Seems to come from right underneath, so I assume the carrier bearing is shot. Gonna measure my driveshaft today and order up the replacement.
Old 04-29-2007, 09:32 PM
VolvoDriver's Avatar
here's a center bearing!
yert315
01-10-2023 12:47 PM
XC70AA
2001-2013 model year XC70
08-19-2020 06:48 PM
Wing0
12-13-2013 02:39 PM
valerie
08-26-2004 06:13 PM
dako
11-10-2003 01:49 PM
Quick Reply: shudder when decelerating
