vacuum hose replacement
I got all the hose from Advance Auto Parts, so they carry not-metric hose. The Dorman vacuum fitting packages give metric equivalents to the inch sizes. I measured the actual fitting diameters using an inexpensive, what's the word, caliper? micrometer? that I got at Harbor Freight and the lengths with a tape measure. I rounded up a tad in lengths, best too long and trim then too short.
- brake booster vacuum line: 3/8" ID x 12.25 " length
- fuel pressure regulator to throttle body: 5MM (3/16") ID x 11" length
- flame trap nipple to throttle body: 5MM (3/16") ID x 9.25" length
- flame trap to intake hose: 16MM (5/8") x 11.5" length
- intake hose to sensor? 3/4" ID x 18.25" length
- sensor? to intake manifold: 3/4" ID x 11" length
- intake manifold to vacuum tank in front bumper: 3/8" ID x 7 feet length (this hose tees to hvac control system, and has the hvac check valve in it).
- throttle body to evap canister, small: 3.5MM (1/8") ID x 40.25" length (on my car, at least, this was a 1/8" OD hard line with replaceable rubber ends - I reused the line and bought new ends: 1/8 ID x 1/8 ID 90 deg elbow to throttle body and 1/8 ID to 3/16 ID straight to canister)
- throttle body to evap canister large: 7/32" ID x 41.5" length. The 7/32" works but was a tad tight at the throttle body, 5/16" was too loose. Next time I'll try harder to find 1/4" ID.
And after doing all the above, I now find one of our friends at brickboard pointed me to the vaccum hose FAQ section I had missed until now:
http://www.brickboard.com/FAQ/700-90...oseReplacement
So, you can go domestic at the FLAPS like I did, or use the brickboard FAQ and buy metric by mailorder.
Hopefully the combination of info here will be useful to another newbie like me...
