Voltage on cold start valve Volvo 240 1990
Old 03-28-2017, 02:14 AM
rainmekker's Avatar
Default Voltage on cold start valve Volvo 240 1990
Does anyone know if there is 12 volt that is the voltage on the cold start valve, or is it another voltage. It is hard to get an exact reading. I guess it is because it is only on for an short periode. Depends how cold it is. I have big problem starting when it is colder than 8-10 degree Celsius. The coolant temp sensor is working well, that I have testet. Engine B230F
Thanks form Norway if somebody knows.
Old 03-28-2017, 02:00 PM
one pin of the CS injector gets its power from the main relay (often called fuel pump relay), same as all the other injectors, and the other pin is momentarily 'grounded' by the ECU to fire the cold start injector, just for a second or so when you crank.... easiest way to see if its being fired is to get a couple 'noid lights', you plug these in between the injector and its cable, and they blink when the injector is fired.
Old 03-30-2017, 04:18 AM
rainmekker's Avatar
Thanks a lot. I will try that.....
Old 06-16-2017, 09:54 AM
rainmekker's Avatar
Problem solved. It was the flywheelsensor and a combination of bad plugwires, distrubutor cap and plugs. Runs fine now :-)
92Sedan
01-27-2015 04:09 PM
92Sedan
01-06-2015 09:21 PM
ejpomeroy
10-04-2011 06:06 PM
volvoQ's
09-07-2010 05:29 PM
dldunckel
01-20-2010 07:02 PM
Quick Reply: Voltage on cold start valve Volvo 240 1990
