volvo 240 - no fast idle at startup - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 10-18-2012, 09:25 AM
Default volvo 240 - no fast idle at startup
when I start my 1990 240, even when it's really cold out, there is NO fast idle for warm up. What is the cause and how to fix it?
(i breezed the forums and found something about an idle position sensor but that was on a carbed 87)
Old 10-18-2012, 01:46 PM
okay... so my situation could be the same as a rough idle? Mine however doesn't idle rough at all. Starts up low idle and is just on and smooth. seems strange to me that it never coughs or sputters - so you'd think that it is not an issue if no problem. it will be when it's 5 degrees outside and I have to keep my foot on the gas just to warm it up.
Old 10-19-2012, 07:32 AM
There shouldn't be any fast idle at startup. The idle circuit in these cars is a feedback control mechanism where the ECU regulates the amount air entering the intake via the idle air controller. It tries to keep the idle around 700 RPM regardless of the temp.
I had one of my 240s have a high idle when it was really cold out and that was due to a sticky idle air controller. I cleaned it out and it idled normal after that.
Old 10-21-2012, 08:24 PM
while I'd like to believe that can you read this thread?
Idle Air Control Valve Symptoms?
Old 10-21-2012, 11:39 PM
Former Moderator
indeed, none of the 240/740/940's I've had idle fast when cold. my 1992 745T starts are the first 1/2 crank and doesn't even seem like its running but its idling at the same 650 or so it idles at all the time.
on my 740 specifically, I know I need to clean my IAC as my engine periodically stumbles a second at idle before it recovers, but thats another problem.
Thread Thread Starter Forum Replies Last Post
Volvo dying at idle or going too fast? hawkreborn Volvo 240, 740 & 940 17 03-07-2013 10:33 AM
Ruaway Volvo- Intermittent Fast Idle theboy455 Volvo 850 3 02-19-2008 10:21 PM
87 240DL fast/slow idle (irregular!) repeatclicks Volvo 240, 740 & 940 2 11-06-2007 10:30 AM
Cold startup stalls due to very low idle speed 850forum Volvo 850 25 10-11-2007 01:03 PM
Fast Idle Stuck jmana Volvo 850 9 09-11-2007 09:59 PM
Tags
1992, 240, control, fast, forum, high, idle, idles, low, start, starting, startup, sticky, valve, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
