'92 940 Turbo; Speedo yes, odometer/trip counter no
Old 07-06-2012, 11:47 PM
cmarino's Avatar
Default '92 940 Turbo; Speedo yes, odometer/trip counter no
I have a '92 940 Turbo. when you first turn the key on the speedometer needle jumps then settles back to zero (don't recall if it did this all the time and just noticing it now since I'm watching the odometer). The speedometer seems to work fine when driving, but the odometer and trip counter don't work/advance...once in a while it will advance for about 10 miles then stop again. Where does the speedometer receive its signal from and does it also feed the odometer/trip counter or is this operation mechanical within the instrument? Thanks ahead of time for any responses!
Old 07-07-2012, 01:27 AM
sounds like the dreaded stripped gear inside the odometer to me.
Old 07-07-2012, 06:04 AM
cmarino's Avatar
appreciate the quick response! Is the part available and something that can be changed? It wouldn't be the first time I've pulled an instrument panel...not what I call a joy in life!
Old 07-07-2012, 09:26 AM
lev's Avatar
lev
lev is offline
The resistors in the speedo are dying... '91-92s are super prone to this. The brickboard.com has a good writeup on the repair and it's not easy. I have never done it--I get used ones.
850_96
07-08-2010 02:05 PM
aytchgee
11-20-2009 12:11 PM
demonooooo
12-30-2007 09:23 AM
pbruin
Engine & Internal
08-08-2005 10:03 PM
rustexpert
02-26-2005 06:06 PM
Quick Reply: '92 940 Turbo; Speedo yes, odometer/trip counter no
