Where can I buy a replacement DOOR PANEL? (The interior plastic)
Or how can I fix this thing up some?
My back right door panel is falling off a bit at the top. I think it will stay up for a while, but the clip right under the small window (close to the C-pillar) and now another clip [right next to it] have come off the plastic panelling and I'm worried that there's no easy solution to fixing this asides from replacing it.
If anyone has taken off their door panels, they'll know I'm talking about--the clips are imbedded into the door and are hard to put back on or replace.
Anyone got a solution?
RE: Where can I buy a replacement DOOR PANEL? (The interior plastic)
In the past I've epoxied the tree clips back into the door panel and I've also been able to get away with using double sided tape. It just depends on how many clips are loose or missing. If there is no way to epoxy the tree clip back on than a trip to your local junkyard may prove worthwhile.
ingydrummer
01-18-2013 03:29 PM
tylerminnick
11-14-2011 01:22 AM
