1988 760 Fuel Pump Relay - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 09-01-2010, 10:45 PM
Default 1988 760 Fuel Pump Relay
Hi,
I am having a problem with what I think is the fuel pump relay on my '88 760 turbo.
  1. Does anyone know the part number for this relay so I can order one?
  2. Does anyone know where this relay is found? I heard it was behind the ashtray if this is true anyone have any detail (pics would be helpfull) on what needs to be removed to access it?
Thanks for any help...
-Luger
Old 09-02-2010, 09:39 AM
swiftjustice44's Avatar
1362914 for both the B280 as well as the B230FT. It is a different relay than used in the 740's and 240's but I believe it is still in the same location, just shaped differently. I could be wrong about the location. I'll include the normal location photo. below. I stock them here at the shop if you can wait until Saturday or Monday for delivery. $28 shipped.
Here's the normal location...remove the ashtray and lift the tab up on the panel above it and then pull up and out. The fuse/relay tray will actually pull out somewhat to improve access.
This is what you're looking for...
Old 09-13-2010, 11:12 PM
Default 760 Fuel pump relay location
So I finally got the time to tear apart the stereo console of my '88 760 in search of the elusive fuel pump relay. After taking out the upper and lower stereo (thats right I am still rockin the stock cassette deck not that I would even know where to find a cassette anymore) and the plastic bit that holds everything in place I realized two things...
  1. There is a much easier way to access the relay terminal.
    (Through the plastic cover in the passenger side footwell only two little screws! SO easy!)
  2. The picture of the relay terminal looks different than the picture I got earlier in this thread.
So now I know where to look and how easy it is to get there I need to know which relay it is that I need to replace. this is the picture of the relay terminal in my car...
Help on this would be helpful!
Thanks,
Luger
Thread Thread Starter Forum Replies Last Post
Volvo 850 random stalling and hard to start. Testing Fuel Pump and Fuel Pump Relay 1995Volvo850 Volvo 850 13 08-05-2013 11:19 AM
Fuel Pump/Fuel Pump Relay spidersilva Volvo 850 8 08-17-2011 07:23 PM
Fuel pump for 1988 volvo 740gle elguzzy Volvo 240, 740 & 940 1 11-22-2008 10:12 PM
'90 240: fuel pump working, pump relay OK. Regulator? montysano Volvo 240, 740 & 940 2 09-09-2008 11:52 AM
help: Fuel Pump & Radio Relay 87 740 gle crazypixie Volvo 240, 740 & 940 1 01-22-2005 01:01 AM
Tags
760, 88, b280, fuel, located, location, med, picture, problem, pump, relay, relays, removing, symptoms, volvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
