1996 960 P0117 error code
i was throwing a P0115 error code and car would not cold start unless my cars key was in the on position for around 15 minutes then it would start. now i got a new ecu that fixed the problem for a few days now my car throws the code P0117 code for a engine coolant curcuit low input.... any ideas of what that could be... when i start my car it has trouble with the throttle when i put the gas on while its cold but once it warms up it does fine.... my temperature guage also jumps around from sometype of electric spike.... any input would help,,,,
RE: 1996 960 P0117 error code
i had replaced that before when it was throwing the P0115 code and it did not change the situation... and i just put in a new thermostat a few months ago... could it still be the sensor if i have tried it before.... my code says it is a coolant circuit low input problem....
That is not a common problem all I can do is give you this like to get a wiring diagram to go from there.
http://www.volvotechinfo.com/WD123/
