'95 960 - OBD port lcation?
Old 09-02-2015, 01:18 PM
campbem's Avatar
Default '95 960 - OBD port lcation?
Hello,
Trying to find the blasted ODB port location on our 1995 960. My web searches are coming up empty. Each place that is suggested, is wrong. Or I'm very blind and am not seeing the hidden panel. Also, does anyone know if its a ODB I or II series?
Many thanks
Matt
Old 09-03-2015, 11:33 AM
southpaw47's Avatar
Originally Posted by campbem
Hello,
Many thanks
Matt
Does not have a typical OBD port Pop the hood and look around the driver side strut mount. You will see a lack plastic box. Pull the cover and read the label for instructions. There is a jumper plug and 3 mini ports for the jumper. Read and record the red light pulses for the history. It will signal a series of pulses i.e. 3 - 1 - 2, etc. Those numbers translate to an assigned problem.
https://www.brickboard.com/RWD/volvo...rts_codes.html
rob17san
11-13-2019 11:50 AM
rspi
09-15-2012 09:06 AM
TonyS
04-26-2010 12:17 AM
trooperone
03-05-2009 07:50 PM
alexeyt
01-16-2008 06:54 AM
Quick Reply: '95 960 - OBD port lcation?
