1990 760 turbo BRAKE PROBLEM
Old 07-17-2011, 02:49 AM
ldou0110's Avatar
Default 1990 760 turbo BRAKE PROBLEM
Soft pedal Replaced brake hoses bled lines no pedal any ideas
Old 07-17-2011, 06:46 PM
Typhoon's Avatar
Pull the front calipers off and check the slide pins, I bet one or more is sticking. I just spent months chasing this on my car. If they're sticking, the inner pad will be a lot more worn than the outer pad.
Old 07-18-2011, 12:13 PM
ldou0110's Avatar
Default 760 brakes
Thanks will check that out tonite. How much pressure should I have at the caliper. I have very little
Old 07-20-2011, 09:03 PM
ldou0110's Avatar
Default 1990 760 Brakes
I Think you solved my problem. Left front seems to be stuck Tried to free it up. flushed then fluid and refilled bled off got fluid to three wheels cannot get fluid to left front. Also used Dot 3 before I realized it needs Dot4. does this make a difference and do I need to replace the caliper. Thanks for your help
Old 07-23-2011, 09:16 AM
ldou0110's Avatar
OK I've taken all calipers cleaned made sur they were working. Bledn off have fluid to all but left front. checked lines going into thew ABS module ??? have fluid to all in lines and all out lines except the left front. Any Ideas please
bdougherty28
05-20-2012 07:43 AM
YURPLESs
01-30-2006 09:09 PM
Someone
08-18-2005 09:59 PM
Someone
08-16-2005 10:51 PM
wbrios
05-11-2003 01:04 AM
Quick Reply: 1990 760 turbo BRAKE PROBLEM
