A/C compressor works but no cold air ?
In addition to what Bluewater1 did here, in your case, I would also replace the Heater Control Valve (which is in the engine compartment, on one of the heater hoses/lines). These valves are cheap: $ 15-18 shipped.
When you check the Vacuum Controller, check the vacuum lines for cracks. Check also the vacuum reservoir for cracks.
I'm guessing you have automatic climate control? ACC? If so, there is also a very good chance the controller is weak or bad. On my 760, I could not use the auto position. I had to put it about 85 degrees and when the temp got down to that, I would start easing it down a few degerees at a time. Eventually it would cool at the temp I wanted. Air flow diminishing is a vac issue. It's quite possible you have a number of issues going on simultaneously.
blackbrick
2001-2013 model year V70
08-14-2014 07:11 PM
gianni
2001-2013 model year XC70
09-18-2013 03:33 PM
