Can't open driver door from exterior of car
Works fine from inside. Took door panel off removed exterior door handle and discovered the problem. The white plastic connector link that connects the operator to the rod has broken in half. Does anyone know of a source for this fragile part? See the image below. The part I need is the white plastic link.
1995 960 Wagon
1995 960 Wagon
Found a used unit @ Voluparts, Voluparts | Volvo Parts Warehouse | New, Used, & Rebuilt, my good guys supplier. $20 + $5 s&h. Good answer on the rear door switch out. Never thought of that. This is just another piece of Volvo plastic that has deteriorated on me. My fuel door plastic hinge went a few months ago. That was easily found on E Bay. Wasn't able to find that connector via E Bay this time.
Thank you for the heads up.
1995 960 Wagon
1995 960 Wagon
Thanks...i found the same source and got one...just found a thread on removing a door panel ona 97 960...great info... a $50 part(used) and my own labor..saving at least $150 doing it myself...that is the power of knowledge...Thankyou all again...
Take care when removing door cards. I broke every fastener in the process. Clips and pins configuration. Do you have a link for that procedure. I need to go back in and tweak the link arm. I bent it during the fix and the outer release latch binds big time.
Getting the door panel off was easy...as it had already been done before...and removing the old latch as well...however I havent figured out how to reconnect the replacement to the rod...theres very little room and you're working by feeling as theres no way to see back there...this isnt as straightforward as i would have hoped...
roosterstoker
03-05-2016 08:20 AM
arifiano
06-07-2010 10:06 PM
