Can't open driver door from exterior of car
Old 09-09-2015, 02:50 PM
southpaw47's Avatar
Default Can't open driver door from exterior of car
Works fine from inside. Took door panel off removed exterior door handle and discovered the problem. The white plastic connector link that connects the operator to the rod has broken in half. Does anyone know of a source for this fragile part? See the image below. The part I need is the white plastic link.
1995 960 Wagon
Old 09-09-2015, 08:36 PM
VDonkey's Avatar
I got one from ebay.
For now, switch the handle with the rear door.
Old 09-10-2015, 09:07 AM
southpaw47's Avatar
Found a used unit @ Voluparts, Voluparts | Volvo Parts Warehouse | New, Used, & Rebuilt, my good guys supplier. $20 + $5 s&h. Good answer on the rear door switch out. Never thought of that. This is just another piece of Volvo plastic that has deteriorated on me. My fuel door plastic hinge went a few months ago. That was easily found on E Bay. Wasn't able to find that connector via E Bay this time.
Old 11-10-2015, 06:12 PM
jands's Avatar
i have a few handles laying around, hope u find what u need
Old 11-11-2015, 07:46 AM
southpaw47's Avatar
Got the part but during the install process i managed to bind the rod and now the release handles has a major bind. Try getting the part in without binding the rod is the mystery. Oh well.
Old 11-12-2015, 11:00 AM
VDonkey's Avatar
The rod is adjustable length and I had to adjust mine. Also the rod fits into the link on the bottom one way and the clip has to snap onto the shaft to hold it in. I hope you can figure it out without taking apart another door to see how it's done.
Old 11-12-2015, 02:15 PM
southpaw47's Avatar
Thank you for the heads up.
1995 960 Wagon
Old 04-27-2016, 10:59 PM
bne's Avatar
bne
bne is offline
Great info...i have the same problem recently so if I cant find the right plastic piece then i'll just swap the handles around back to front...Thanks for all who replied....:-)
Old 04-28-2016, 08:14 AM
southpaw47's Avatar
Seems to be a common occurrence. Plenty available EBay. I found mine there.
Old 04-28-2016, 03:04 PM
bne's Avatar
bne
bne is offline
Thanks...i found the same source and got one...just found a thread on removing a door panel ona 97 960...great info... a $50 part(used) and my own labor..saving at least $150 doing it myself...that is the power of knowledge...Thankyou all again...
Old 04-29-2016, 09:00 AM
southpaw47's Avatar
Take care when removing door cards. I broke every fastener in the process. Clips and pins configuration. Do you have a link for that procedure. I need to go back in and tweak the link arm. I bent it during the fix and the outer release latch binds big time.
Old 04-30-2016, 04:35 PM
bne's Avatar
bne
bne is offline
not off hand...i relocate it an post it up...
Old 04-30-2016, 04:50 PM
bne's Avatar
bne
bne is offline
Old 05-19-2016, 07:08 AM
bne's Avatar
bne
bne is offline
Getting the door panel off was easy...as it had already been done before...and removing the old latch as well...however I havent figured out how to reconnect the replacement to the rod...theres very little room and you're working by feeling as theres no way to see back there...this isnt as straightforward as i would have hoped...
karutunian
03-27-2021 05:44 PM
roosterstoker
03-05-2016 08:20 AM
klod622
01-31-2010 06:11 PM
casualfc
01-15-2010 07:58 AM
Quick Reply: Can't open driver door from exterior of car
